what amp would you use? money isnt a huge factor. just good clean power
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
sundown 1200
DC.jpgDC POWER
how big are the fosgates?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
What size are the Kicker CompVR's?
Do you want a sealed box or a ported box?
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
i'm going to assume that they are the 12" versions, 400 rms each.
i think you should go with the fosgate T1000.
OR you can get a T1500 and run it at 2ohms @ ~1000rms.
If you decide to upgrade your subs later on, you'll already have a stout little amp that provides 'enough' power :)
*My 2 pesos
TNCB
....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra?
12's ported box built to specs
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
when i got mine i was surprised by the size. Dimensions: 18" L x 12.8" W x 2.66" H
the sundown is a little smaller and does 1200w at 12.8v
DC.jpgDC POWER
Quite honestly you should be fine with any amp that does 1,000 watts cleanly to 2 CompVR's no matter the size. 1,000 watts might be a bit much on the 8 incher's.
Kicker offers a 750.1 and a 1000.1.
