T-line Box Design Help
sketch-up? hmm never heard of it ... I wouldnt know where to begin on using it really. Anyone mind trying to sketch it up?
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Ok I did a bit of editing... made the box 36 3/4 x 24 3/4 x 15 with the tunnel 13 1/2 x 7 7/32 x 84 1/4 messed with the port layout which looks better than before imho. What you guys think?? Btw where do u start meassuring the tunnel? as the wall behind the sub? from the center of the sub? From the front of the sub? I did it from the wall behind the sub, just making sure i did it right.
Edited by SojiaRaggs9000
i usualy mesure from the center of the back of the sub.
and also i would stick to the fs of the sub. you will be suprised how good it will sound even at that higher feq.
if its to high for you, you can also line the box in stuffing to slow the waves down to make it tuned lower anywase.
other then that just try and see how it comes.
only can learn by doing yourself.
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
I like making things and love learning new things with my hands so its all good. I figured out how to use sketch-up ... its a cake a walk compared to AutoCAD. I adjusted the port a bit so that I was measuring the length starting from the center of the sub. Should I move the driver hole over just a bit to the right or nah? IDK but im not sure if there will be mounting issues with it it being that close. What do you guys think? I didn't 45 the corners , but don't worry about that.. they will be 45'd.
Dont forget to round all the ends and put 45s in the corners. Thats an awesome looking box and should get really low.
2000 White Ford Ranger
5" RCD lift
33x12.50 Mickey Thompson MTZs on 16x8 Mickey Thompson Classic 2s
Euro Altezza tail lights
5% window tint
Clarion Indash
4 Q Power 15s
1 Sundown 2000
1 DC power 300 amp alt(on the way)-soon to be 2
2 powermaster d925s batteries
Second Skin Deadener
Highs/mids amp-Crossfire 404
Door speakers-2 5x7 mb quarts and 1 5 1/4" black max up front, stock 5x7s in the rear
Soon to Come:
Lots of SA-8s
2 Sundown saz 3500s(possible 4500s)
5-7 d3100 batteries
custom clamshell
BNC 8s for mids
undecided tweeters
Technically the distance should be measured from the wall of the closed end of the tube. This is where the node of the wave will be located and tuned by the length of the port, all the sub does is create the wave, not determine the resonant frequency.
http://hyperphysics.phy-astr.gsu.edu/HBASE/Waves/clocol.html shows a pic for you.
edit: also, why not just shorten the width of the box to get rid of that dead space? It isn't all that hard to calculate what the width of the box should be... unless you just want the box wider than it needs to be. if you would like I can explain a simple way of calculate it up so you aren't just doing a hit and miss calculation...
Edited by rusty959
so messure from the wall behind the sub on the left? grrrrr lol......
edit1: Nah I want to to be a certian size. Plus I can run my wires from the sub to my amp through there so it works out.
lol, technically yes. that being said its only about 6 inches difference?
Edited by rusty959
  • Who's Online   1 Member, 0 Anonymous, 1212 Guests (See full list)
