So im tryin to design a box for an Fi BL 18 and i need two 6" round ports, so i plug in my numbers in this calc: http://www.carstereo.com/help/Articles.cfm?id=31, and it tells me that my port length should be 24.23 in long..does that mean each port has to be that long? Or does it mean that i divide that by two and make each port 12.xx long?
Here is the box so i dont really have that much room to have two 24" long ports going on in there, and a slot port would be really dificult with the back angled like it is. Any help would be cool thx.
I just drew the ports to be 12" long so you can get the idea of how much room there is in there, the box is 5.2cubes net and i wanna tune it to 32hz.
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
You could go with 4 3" ports and it would be right at 12 and a 1/8" long and that's each.
Edited by Bunker
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
x5 thats each port.
or make the box bigger, my two 6" ports were ~12" @32hz but my box was 7cuft
-Drew
uhoh_45 said:
Well it looks to me like he's trying to fit a box in a tight space, hence the angle of it. So I doubt making the box larger would be an option
yup yup, its going behind the second row seat in my jeep Cherokee and i want to retain as much space as i can in the trunk area, i could make it much larger but i figured 5.2 cubes is just at the recommended specs. Would just using 1 6" port result in too much port noise?
Here is the same box but it's for 2 12's, the box for the 18" will be 2" less depth wise
Edited by eliassami5
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
Hang on so you're going from 2 12's to an 18 and you're making the box smaller? That doesn't make much sense :P
IMO unless you have well over rated RMS power to the 18 you'll be choking it in a box that small, a 15 might be a better option given your constraints.
10.x volts fo' life!
The box for the 2 12's was way oversized and it is a bit over 6 cubes, i figured i could make a more efficient box for the 18 and give it the minimum recommended space which is 5 cubes. And how would i be "chocking" it?...as in i dont have enough port area or as in the box dosent have enough air space? And it's only gonna be fed ~1000 watts RMS.
So ur saying more power = smaller box, and rms power = larger box?
Here is an update on the box..its 6.9 cubes tuned to 32 hz. Im worried about there not being enough space between the bottom of the ports and the bottom of the box..
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
  • Who's Online   0 Members, 0 Anonymous, 908 Guests (See full list)
