i ahve a pioneer deh 2000mp head unit and a old kenwood 2channel amp. i hooked them to my subs and all it does is pulse in and out. no sound no anything just pulse in and out. i set the gain all the way down and all the way up and still nothing. any ideas???
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
they go to full excursion out then back in. it does it pretty slow.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
wanna get this fixed. i know someone knows.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
amp powers on and evrything fine just dont send anything out. im 100% positive its something wrong in the siganl but idk what
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
the only thing I can think of is polarity.
the technique is used for speakers when you don't know which is + and which is -
Wouldnt be thehoe92 without teh purple
i know positive form negitive. the wiring is right. its in the signal going to the amp. rcas are not the problem ive switched like 2 pairs
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
lol I'm not accusing you of not knowing.
it could be that the remote wire that you are using that is coming from the head unit does not have enough voltage going through it?
I'm thinking of everything ATM man.
Did you try a different rca output off the headunit like a front or rear? Just to test that its not the sub output channel.
Also is your subwoofer volume turned up on the headunit?
did the rca jacks in the amp come unsoldered or break the joints on the board?
Does the amp work fine in another enviorment(different vehicle, or bench testings)?
it only has one output i dont have a sub volume thouhg. no the jack never came unsoldered and yes the amp works in another car. thats why i think its a signal problem.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
