Boon Posted April 21, 2009 Report Posted April 21, 2009 If you Great Stuff the panels it's illegal for Street class dbdrag, just so you know. Replacing the seals works well and if you wanna get serious then find any latches that you can get at and either move them inwards a little or bend them in a bit with a metal bar or hammer. Sure you have to slam the doors to make them shut properly but you can gain a little from the extra force holding the door shut. Quote 10.x volts fo' life!
moh.vze.com Posted April 21, 2009 Report Posted April 21, 2009 If you Great Stuff the panels it's illegal for Street class dbdrag, just so you know. Hmm. i didn't know that. Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Boon Posted April 21, 2009 Report Posted April 21, 2009 Hmm. i didn't know that. 3-10a: Expanding foam may be used sparingly throughout the vehicle to seal small openings or reduce vibration, but may not be used to fill voids or other large cavities (such as the dashboard or doors). I think 'sparingly' was decided to mean no larger than 'a fist' in any single location. Sucked for my friend who stuffed a whole lot in his rear quarter panels... good luck getting it out once it's in there Quote 10.x volts fo' life!
uhoh_45 Posted April 21, 2009 Report Posted April 21, 2009 wall the bitch and your gate will hardley flex Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
