Box is 6ft3 net * 32hz , 77.5sq inch port for a loaded 18" btl , sub up / port back , power is going to be a sundown 3500d * 1ohm .
I was thinking of furthering the 45's to the top and bottom running horizontially{ very small peices not huge 45's like you see ) , not in the port though . More to get rid of as many 90 degree angles as I can . Do you guys think I should make the 45 on the port side bigger/wider ?
Also thinking of putting a peice horizontally of sanded and rounded edged 3/4" mdf peice about 4" in length inside the middle of the 5" width port . Thought of making an extended peice that continues horizontially almost to the 45 since the area is wide open there .
The top I have 2 peices cut so it is getting double baffled , sub will mount on second .
Thinking 1/2" All thread making almost a cross inside the box mounted as close to middle as possible dodging the subs massive magnet . Maybe 2 peices of wooden dowel rod's running vertically on side of sub edge to help support the middle baffle area . I am going to try to mount the sub as far away from the internal port opening as possible .
Here's some picture's of my box so far .
Only my 2nd box I designed and built myself and I dont have a table saw or router , so take it easy .
Edited by Joker
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
2x4s is wat i use for bracing. always works for me
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
I didn't want to use 2x4 , they eat to much space and block the airflow. You have a wall , how about for just the common box .
threaded rod dowls 2x4s
could brace like this
theres alot of different ways
(hope users whos photos those are dont get mad or nothing)
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
allthread or dowel rods, like shown in the last 2 boxes. I prefer all thread, but dowels are cheaper
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
