LiL PiNoY Posted April 23, 2009 Report Posted April 23, 2009 I have Amps: 2 Alpine pdx 1.1000 1 Alpine pdx 4.100 Subs: 2 Alpine type x's 2 pairs of Alpine type r components head unit Alpine 9884 225 amp alternator made by Stinger 1 Kinetik Hc 2000 1 Kinetik Hc 2400 1/0 guage everywhere except from the amps to the distro. block is 4 guage lights still dim like crazy is everything ok???? should i get a battery isolator??? i usually play the volume at 30/35 at idle it drops to 11.7v when i play it at full tilt. if this is not okay what should i do to help it??
CaptainzPlanetz Posted April 23, 2009 Report Posted April 23, 2009 I haveAmps: 2 Alpine pdx 1.1000 1 Alpine pdx 4.100 Subs: 2 Alpine type x's 2 pairs of Alpine type r components head unit Alpine 9884 225 amp alternator made by Stinger 1 Kinetik Hc 2000 1 Kinetik Hc 2400 1/0 guage everywhere except from the amps to the distro. block is 4 guage lights still dim like crazy is everything ok???? should i get a battery isolator??? i usually play the volume at 30/35 at idle it drops to 11.7v when i play it at full tilt. if this is not okay what should i do to help it?? Did you do the Big3, if you didnt even with a H.O. Alt, your power is gonna be bottle necked and you will not get the advantages of the H.O.Alt. Edit: Also most H.O. Alts, dont put out full power at Idle, usually about 1200 to 2000 rmp, but you can fix that by going with a smaller Alt pulley. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
tibs Posted April 23, 2009 Report Posted April 23, 2009 what about when you have the car at 2000 rpm? do the big 3? clean metal for grounds? Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
