Setting Amplifier Gain Control
dbwesz
i've a question.
whats the best way to put your gain?
full as possible open or keep it closed as possible ?
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
good find Ernesto!!
now we do
NoFearX18 said:
trainman0978 said:
stickied
Good...Too many of these threads
yea i deleted the other posts and just stickied this because i thought it was pretty important
NoFearX18 said:
trainman0978 said:
The bad thing about that link is that they only give the settings for the JL amps.  Just so everyone knows, the formula is AC volts squared, divided by impedance (ohms), equals watts.  So if I want 2000w @ 1ohm from my amp I'll need the sqare root of 2000 x 1 which = 44.72.  I'll set the output of my amp to 44.72 AC volts.  Or say I wanted 1500w @ 2ohms.  It'll be the square root of 1500 x 2 which = 54.77.  I'll set the output of the amp to 54.77 AC volts.
http://www.subwoofertools.com/forum/setgain.asp
try this one..it's better than the JL..only thing is, it doesnt provide a video like Jl's but it's straight forward...calculate the voltage, follow the steps and you're done
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
  • 1 month later...
