Alpine S-10s
white4d96
they should be able to take any decent qualiy brand will take over rms some more than other but 50 over is nothing you should be able to do with ease but what the maxx on them
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
ok so the maxx is 900watts you should be able to do at least 450 or 500 no problem ive had cheaper speakers than that and ran almost there maxx with no problem
I have heard they can take slightly above RMS daily.
Is this true?
Im thinking 350rms, so 50 over...
i wouldnt man.... i have 4 of the dual 4ohm models and based on my experiences with them they should have been rated for a lower rms rating.... i was running 300rms each to 2 of them and they kept bottoming out.... in my new build im running a mrp-m1000 to them and they will be seeing 250rms each and that is quite enough......
obviously you can do whatever you want but my advice is to not try to push them past their ratings.... 250wrms seems to be safe for me... let me know how they do with more power if you decide to push them....
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
ya let me know what you do as far as power wise like i said i run my things a little over and i dont have a problem but diffrent people diffrent options
only go over the RMS if ur running a GOOD amp. dirty rms = ftl
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
What model number are/were yours? Mine are the older ones, the 1042D's...with the stainless dustcap.
Too many projects, too little time...
mine are the newer 1043d's mine are the kevlar reiforced..... since yours are the older ones you might be able to get away from it i know the olderones had a bit bigger magnet and motor.... they are all nice subs though... just not super power hungry... which is good in some instances...
3 Kinetik Hc2000's
Dual 200amp alts.
  • Who's Online   0 Members, 0 Anonymous, 571 Guests (See full list)
