What is the difference? Is there a difference in loudness?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
nope its the amp that matters
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
well I was looking at amps and I realized that a 2 ohm gets more power to the sub than a four ohm. is that more unsafe
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
example, 2 subs dual 2ohm, would give you .5ohm load or 2ohm
2 subs dual 4ohm would give you 1ohm and 4ohm load
so you would need a amp that works with the ohm loads youre able to get from your subs
yeah the only difference id say there is, is that if your only getting one or if your getting a certain amount of them so you can make differnt loads for differnt amps and power handling capibilities.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
perfect thanks guys and mrafrica I will have to see your system sometime in the future. I live in germantown. I think I have finally met someone from this forum that is from wisconsin :)
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 524 Guests (See full list)
