Pioneer~Saturn Posted April 25, 2009 Report Posted April 25, 2009 Hey guys, I was wondering if anyone would know where I can find a 5-rib, 79.8 inch long serpentine belt? (or within half an inch of that might do)...the factory length is 5-rib 77.8 for a reference and autozone/advance auto both dont carry anything within 2 inches of what I need. Im going to look at Napa tomorrow/Monday, they might have a better/different selection on belts. Anywhere you'd suggest to look? Thanks in advance. Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
badasschevy Posted April 25, 2009 Report Posted April 25, 2009 (edited) napa would probably be your best bet. i was looking at summit racing and the next size belt up is 81.75 for a goodyear. http://store.summitracing.com/egnsearch.as...+115+4294791882 Edited April 25, 2009 by badasschevy Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components
Pioneer~Saturn Posted April 25, 2009 Author Report Posted April 25, 2009 Yea, thought theyd be the best bet...that belt may work but I doubt it ...Id even be interested in a custom-made belt if that'd be the case but I dont think anyone does that. Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
bobonit Posted April 25, 2009 Report Posted April 25, 2009 The goodyear part number is 4050778 for their 5 rib 77.8" gatorback belt. Amazon had it for $20.14 in stock here: http://www.amazon.com/Goodyear-4050778-Gat...2707&sr=8-1 Hope that helps. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log
badasschevy Posted April 26, 2009 Report Posted April 26, 2009 (edited) Yea, thought theyd be the best bet...that belt may work but I doubt it ...Id even be interested in a custom-made belt if that'd be the case but I dont think anyone does that. you can always do what steve did with his. he cut off a rib to get his to work. i found a 6 rib that 79.00" http://store.summitracing.com/partdetail.a...mp;autoview=sku heres a 79.75 but its 8 rib http://store.summitracing.com/egnsearch.as...+115+4294742251 and a 79.87 6 rib http://store.summitracing.com/egnsearch.as...+115+4294749022 like i said you'll have to cut off a rib or 3 to work, but just make sure you have the right size before you do. Edited April 26, 2009 by badasschevy Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components
Pioneer~Saturn Posted April 26, 2009 Author Report Posted April 26, 2009 Bobonit: that's the factory length that wont work, but thanks. And yea, it looks like im gunna try it with a 6-rib belt and cut a rib off and see how well it works and if it'll hold up for a decent amount of time. Im just gunna keep the factory length one handy with some wrenches incase it gives out on me Quote Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
bobonit Posted April 27, 2009 Report Posted April 27, 2009 Bobonit: that's the factory length that wont work, but thanks.And yea, it looks like im gunna try it with a 6-rib belt and cut a rib off and see how well it works and if it'll hold up for a decent amount of time. Im just gunna keep the factory length one handy with some wrenches incase it gives out on me Yea, sorry. That's the closest I could find on Goodyears website, the next closest size was a couple of inches off. Good luck with resizing the wider one. A nice fresh carpet blade should do it pretty good. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log
