uhoh_45 Posted May 8, 2009 Report Posted May 8, 2009 who cares if it looks pretty as long as its loud to back up the ugliness R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 who cares if it looks pretty as long as its loud to back up the ugliness Lol, very true...and it's still my daily driver so Im going to make it look acceptable as well. And there will also be a pair of components in the rear as well that will be fiberglass into the corners of the rear deck area/rear suspension bolts are. so that will fill those two holes in the back there and there will also be fiberglassing on the sides of the enclosure to seal the sides of the enclosure up against the rear doors Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
str8outtaneb Posted May 8, 2009 Report Posted May 8, 2009 looks good so far can't wait to see it finished fuck the consequences ain't nothin to a boss
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 Thanks A little done today.. Toar out the excess foam-monster that was pouring out.. 45 degree insert for the corner.. Sealed up.. I decided the rear batteries didnt look mean enough :cool:..so I added some ground runs on the busbar to make future battery/amp upgrades a breeze (so that I dont have to try and get runs on the negative busbar which will have the port hovering over it...it'd be kinda cramped) Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 8, 2009 Author Report Posted May 8, 2009 Some port pieces cut and layed out.. No pics after that because I basically sat down and started seeing what kind of port length I'll be getting with this and I may have to shorten the port a bit because im pretty sure it'll be tuned even lower than I wanted *gasp* with it like this...tomorrow I should be able to get the port dimensions settled and underway on construction.. More as it happens Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
uhoh_45 Posted May 8, 2009 Report Posted May 8, 2009 looking good why the ground upgrade and not positive upgrade as well? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Kasey Posted May 8, 2009 Report Posted May 8, 2009 This thing gonna slam and maybe even http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif "Audio is not a hobby it's a lifestyle" _____________________________Refs_1_Refs_2_____________________________
Pioneer~Saturn Posted May 9, 2009 Author Report Posted May 9, 2009 looking good why the ground upgrade and not positive upgrade as well? It wasnt really just the ground that I'd be doing...I just put those runs on the negative busbar because in the future when/if I upgrade the batteries in the rear...the port will be covering a bit of the negative busbar so I just got that part out of the way...the positive busbar is in full view/reach and wont be a problem to work with...I just did the negatives now because they'd probably be an issue with the port in the way. This thing gonna slam and maybe even http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif Thanks, I hope so Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
sounddesires Posted May 9, 2009 Report Posted May 9, 2009 i think this think is going to wang so hard....for reals...sexy
Pioneer~Saturn Posted May 10, 2009 Author Report Posted May 10, 2009 I think it'll make some noise thanks And here's a bit from today...didnt get a ton done but it's progress Base for the back of the enclosure+port mounted in.. Port side and first port piece mounted to eachother.. The sides arent mounted yet...in these pics the port pieces are just sitting on the base And had a fire...here's one of the cutouts for these baffles.. More tomorrow Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
