The Saturn: Cant Stop There (dual 18's Upgrade)
man seeing stuff like this makes me wanna do a huge build to my rides,
"never drive faster then your guardian angel flies... good think my guardian angel drives a twin turbo ed beast"
"its time has come for those who are different to stand united"
Thanks, lol. You should go for it :)
I just got done resining the inside of the enclosure and laying some mat on the bottom. I may add another coating of resin and mat to the corner areas as well. Body filler has been spread on the corner areas and the 'mouth' of the port that's a bit edgy to smooth everything over...sanding once its done and pics later tonight :)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Got a bit done earlier..
Posted Image
Laying in some mat
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Tonight I will be clearing out my shop (because of the rain we're getting) and getting it inside for some sanding, body filler, more sanding, and most likely get the port put together :)
Hopefully my other Omega get's here tomorrow too, along with wire from knu.
More later tonight hopefully
Team Tupperware
A bit of sanding..
Posted Image
After some half-a$$ sanding I layed on another thick layer of resin to smooth things out..
Posted Image
Posted Image
Layed more resin and mat on the corner areas..
Posted Image
Posted Image
Pretty smoothed out on the 'mouth' area..
Posted Image
More tomorrow, the last port pieces should be in and the back of the port should go on and it'll be structurely finished :)
Team Tupperware
Got the imperfection in the top piece taken care of..
Posted Image
Port piece going in..
Posted Image
Posted Image
First 45 degree insert piece in port..
Posted Image
Other 2 insert pieces in..
Posted Image
Posted Image
45 degree piece for the mouth of the port..
Posted Image
Team Tupperware
Mounted..
Posted Image
^still need to sand a bit in the port on that body filler
Posted Image
Couple overview shots after the dust was cleaned out..
Posted Image
Posted Image
Posted Image
Posted Image
Finished tomorrow :)
Team Tupperware
where did you get those terminals?
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
looks sexy as hell just one question, how big are those terminals they look small in the pic(s) a comparison picture would be nice
R.I.P!
(Nov-29-2009)
92 explorer
current build
Parts-express...it's like a 5 minute drive :) theyre about 10 bucks but are beast
Team Tupperware
this build is lookin sweet, i cant wait to see it all done, and see some vids with some http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif keep the awesome work up
1997 Pontiac Bonneville Black on Black on Black
15" DC Sound Labs Level 5 w/ quad coil in a T-Line tuned to 35 hz
7" Jensen VM9311TS Touch Screen Flip Out w/ J-Link
Blue Custom Trim
Blue Custom Fiberglass Rear Speaker Pods
Autotek Mean Machine MM2000.1
1/0 Knukonceptz KLMX
Rockford Fosgate Twisted RCA's
2 Audiopipe Anl fuse holders w/ 200A Kicker fuses
2nd battery (Soon to be an Odyssey D3100)
Dynamat Extreme Bulk Pack
Custom False Floor
15% Tint All Around
Custom Painted Stock Rims
My Build Log
Tailights
15" Lvl 5 DC T-Line Build
