RamenNoodles Posted May 18, 2009 Report Posted May 18, 2009 Youve got my vote for SOTM. You went out of the norm and did a badass build. ANd im sure it will get louder when you get some real beauty panels in there instead of duct tape haha. Diablo Audio Technologies Fi Car Audio Ascendant Audio
Pioneer~Saturn Posted May 18, 2009 Author Report Posted May 18, 2009 Thanks man I really didnt want to do what everyone and their brother would do..so I just threw this prefab enclosure in there to see what it'd do Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 19, 2009 Author Report Posted May 19, 2009 Uploading a quick vid in the video section more in the future and definitely wasnt turned up that high Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Joeskey Posted May 26, 2009 Report Posted May 26, 2009 u should wood stain the face tht would loook pretty cool "never drive faster then your guardian angel flies... good think my guardian angel drives a twin turbo ed beast" "its time has come for those who are different to stand united"
Pioneer~Saturn Posted May 31, 2009 Author Report Posted May 31, 2009 Thanks guys, and staining everything would get pretty difficult to pull off and look good, lol. 149.5 @ 41Hz yesterday due to the duct tape not being in the rear deck and the sides of the enclosure to try and seal it from the trunk ...not that it's a horrible score or anything, but im really looking to break 150 every run after some work I can hopefully get around to in the near future. I may be cutting the mounting rings for my 2 pairs of rear components tonight...pics if anything happens. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
uhoh_45 Posted June 1, 2009 Report Posted June 1, 2009 damn man seal that bitch up already get off your ass and do work R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Pioneer~Saturn Posted June 1, 2009 Author Report Posted June 1, 2009 Tonight I have some time and I'll be heading out to the shop to do some work...might have to make space and pull the car in though. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
basshead4life Posted June 1, 2009 Report Posted June 1, 2009 i think its time to break out another roll of duct tape and fix the sunroof! lol Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
Pioneer~Saturn Posted June 1, 2009 Author Report Posted June 1, 2009 Lol, possibly. Alright, got a little done today...the sides are sealed from the trunk but there are still large voids in the pits on the sides though..they'll get sealed off as well. The passenger side of the port...straight into the cabin Got a piece cut and 'instant bond'ed it into place.. Foamed around it to seal 'er up.. Same thing on the driver's side The foam became a bit unruley (sp?) so I had to push/wipe it into position with a grocery bag over my hand, worked pretty well. More as it happens And I was a bit confused looking at the pics, but the double-layered back of the port (the panel that the amp is mounted on) makes it look like the side panels of the port dont mate worth crap...but i was just looking at the first layer of that back wall thinking it was the end of the side panel..optical illusion Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
