Pioneer~Saturn Posted May 6, 2009 Author Report Posted May 6, 2009 And here's what happened today, not an extreme amount of progress though, meh.. Got the rear deck's cutting done..cut a bit more off the back area.. The real way to hold your trunk open :cool: Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 6, 2009 Author Report Posted May 6, 2009 The amp will be in the back of the trunk for this setup so the fusing, wires, etc for the amp had to be moved a bit.. ^Didnt really show much of what I did, but I just turned the ground run for the amp around on the busbar so it faced the direction the amp will be...and just took the power runs off until I get more done in the trunk Angled piece cut for the 'step' into the trunk.. Piece made for the step-over to get the enclosure into the trunk.. Mock-up.. Mounted.. More as it happens.. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 7, 2009 Author Report Posted May 7, 2009 Got it layed out and it looks like 12 cubes is in the bag no sweat for net cubes ...it'll most likely be 12-12.5 cubes net, tuned to 31Hz, and 200 sq inches of port Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
thehoe92 Posted May 7, 2009 Report Posted May 7, 2009 still loving this build Wouldnt be thehoe92 without teh purple
Pioneer~Saturn Posted May 7, 2009 Author Report Posted May 7, 2009 Thanks More progress tomorrow Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Stephen Posted May 7, 2009 Report Posted May 7, 2009 Thanks More progress tomorrow where did you get the pocket hole jig? did it come with a bit? you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Pioneer~Saturn Posted May 7, 2009 Author Report Posted May 7, 2009 where did you get the pocket hole jig? did it come with a bit? U can get it at Home Depot for $20 I believe. And yea, it comes with 8 screws, the drill bit, and also a long square-drive bit to drive the included screws in. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Stephen Posted May 7, 2009 Report Posted May 7, 2009 U can get it at Home Depot for $20 I believe. And yea, it comes with 8 screws, the drill bit, and also a long square-drive bit to drive the included screws in. :giggity: thanks you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Pioneer~Saturn Posted May 7, 2009 Author Report Posted May 7, 2009 Lawl, no prob. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Sampsonite Posted May 7, 2009 Report Posted May 7, 2009 still loving this build x2 --Sampson 816-591-6592 www.kcrimshop.com
