Crump Posted April 27, 2009 Author Report Posted April 27, 2009 Just ground the outter end of the rca's, that usually fixes the problem if it's caused by the pioneer unit. If not and your wires dont cross your power, then it may b a problem with the rca's themselves. I'd look into grounding the rca's first Again, would the ground loop isolater work for this? i have it ready to be installed but i want to know if itll work 1st. lol Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Aukland Posted April 27, 2009 Report Posted April 27, 2009 I usually don't prefer them. you're talkin about the rca ground loop iso's correct? Quote Kenwood kdc-x993 Autotek MM100.4 Fosgate power 6.5" components Time for something new
Crump Posted April 27, 2009 Author Report Posted April 27, 2009 I usually don't prefer them.you're talkin about the rca ground loop iso's correct? Yes Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Aukland Posted April 27, 2009 Report Posted April 27, 2009 Like I said I don;t personally like em, and if it's the pioneer issue, may not help, plus the fix for grounding the RCA's will only cost you several inches of wire ea. to fix. Quote Kenwood kdc-x993 Autotek MM100.4 Fosgate power 6.5" components Time for something new
Crump Posted April 27, 2009 Author Report Posted April 27, 2009 Like I said I don;t personally like em, and if it's the pioneer issue, may not help, plus the fix for grounding the RCA's will only cost you several inches of wire ea. to fix. How would you about grounding 4 Rca's? Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Boon Posted April 27, 2009 Report Posted April 27, 2009 Ground loop iso DOES fix the Pioneer issue. Pioneer engine noise is caused by people popping the pico-fuse on the RCA ground so you get an instant ground loop... which is solved by the isolator... Quote 10.x volts fo' life!
Crump Posted April 27, 2009 Author Report Posted April 27, 2009 Ground loop iso DOES fix the Pioneer issue. Pioneer engine noise is caused by people popping the pico-fuse on the RCA ground so you get an instant ground loop... which is solved by the isolator... Sweet and it says that i need to ground it where the H/U is grounded. But it also says that it may work without it so ill give that a try. After i fix my door speaker so i know it was the RCA thing Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Aukland Posted April 27, 2009 Report Posted April 27, 2009 thanks for the info boon, I have used ground loop iso's in the past, but not to fix the pioneer problems. Quote Kenwood kdc-x993 Autotek MM100.4 Fosgate power 6.5" components Time for something new
Crump Posted April 27, 2009 Author Report Posted April 27, 2009 (edited) thanks for the info boon, I have used ground loop iso's in the past, but not to fix the pioneer problems. shitty thing about that is, ill need like 1-2 more. If its the 4 channel Rca's ill need one more, if its the 4 channel rca's and the sub rca's then ill need two more. :censored: And my friend has the same head unit and same Sub rca's. why does he have no engine noise. AND there ran along with the power wire. aint that some bull shit Edited April 27, 2009 by Crump-T1 Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Boon Posted April 27, 2009 Report Posted April 27, 2009 shitty thing about that is, ill need like 1-2 more. If its the 4 channel Rca's ill need one more, if its the 4 channel rca's and the sub rca's then ill need two more. :censored:And my friend has the same head unit and same Sub rca's. why does he have no engine noise. AND there ran along with the power wire. aint that some bull shit Different amp designs can be more/less prone to being affected by ground loops. Also there's a chance his fusible link is still intact Quote 10.x volts fo' life!
