I was looking for a batt to run in my trunk for the summer. As ya'll can see in my signature, i have a pm5100r upfront, and nothing in the back so far. my electrcial is holding up fine because bass boost is @ 0... and gain is like 1/2 up. but i wanna have it full tilt by summer. Im getting an alt after these batts, but i wanna make sure i get good batts. I would just go with the biggest batt i could fit back there, but b/c if room and money constraints, ill just go w/ what i need to run my amps efficiently
so for a saz-1500, i was thinking b/t:
PM d3400
http://mechman.com/store/product_info.php/...products_id/317
2x PM d925
http://www.stevemeadedesigns.com/board/ind...showtopic=43955
the group 31's batts b slaps yo mama is sellin
http://www.stevemeadedesigns.com/board/ind...showtopic=43707
i figured that b slap yo mama batts would probably be the best, but im alil weary about runinng two different brands of batts.
um lmk what ya'll think. thanks
also, if you have other suggestion lmk. i would like to get a PM D3100... but they are to expensive. unless i can get 1 used or an open box sale from mechman, i dont think thats an option.
Edited by 07sOnAtA sp.ed
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Any group 31 battery will be fine.
Edit: Your last two links are the same????
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
thanks i fixed it.
also, you dont think there would be a problem b/c of me running two fifferent brands of batts?
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
theres no problem with running different batts, and idk what kind bslapsyomomma's are or the specs, but for that price its probably your best bet
i can get you an ill deal on anything kinetik/powermaster/optima if you want, hit me up when we're done with school
Team DC
For a saz-1500d @ 1ohm you don't even need a group31 in the back but I do recommend getting the biggest you can. Keeps you from having to upgrade later. It's recommended to use an isolator between them when using different batteries. If the batteries do not rest identically you'll get transfer back and forth which could shorten their life. I'm no expert but it's what I've been told so I steer to the side of caution and don't do it.
thanks for the heads up man
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
  • Who's Online   0 Members, 0 Anonymous, 1508 Guests (See full list)
