I know some of you guys have an old Alpine 3523 amp with the screws too. I gotta dig mine out and I'll snap a picture.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
I havent had time to mess with my amp much, but its model is xa 1120.
It also says mosfet power on it, and I have no idea what that means o.o
7e770874-fae3-49d5-ad82-4cabf106fead_zps d3abdb88-50bf-42d8-9628-e257559ec11d_zps
IG: devinthydude
Mosfets are black critters, usually with 3 legs. They also contain magic smoke, and more often than not when something goes wrong with your amplifier, they release the magic smoke. You'll probably see them under a heat sink of sorts, or some amps like the Jensen you have should have the fluid powered/cooled fets.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Ahahhahahhohohoohohoohohahhahahoohoho.
Ouch, my sides hurt :/
rofl, now that's funny as hell
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
dont make fun of the noob guys!
amps dont have fluid, please dont drill holes/open it/put oil or any other liquid into it
get a multimeter (like 12 bux at radioshack if you dont have one/cant borrow one)
turn the dial to the "20v" part
put the red probe on the amp terminal that is hooked to your battery, the black one to the terminal hooked to ground(just touching the screws you use to tighten the wires in is fine)
if it reads between 12-14 volts youre fine as far as that goes
if not, you have a problem with your power/ground line, check connections/fuses (under hood and on amp)
if you had voltage and it still isnt on, take a small piece of wire and touch it to the positive terminal (again, the one that goes to the battery) and the remote terminal (smaller one, will say "REM" most likely)
if it doesnt turn on, most likely the amp is fried
Team DC
  • Who's Online   1 Member, 0 Anonymous, 610 Guests (See full list)
