Hey guys, yesterday I was driving to a friends house listining to some too short, when my bass just dies.
I have this kind of old jensen 220 watt amp hooked up, and when I had my car on the power light on my amp came on (duh).
But now when my car is on my amps light isnt on and im getting no power to my sub, I checked all the wires and they are all hooked up, but the wierd part is that during some songs my amp gets power again but only for a couple of seconds.
So do amps just die or did one of my wires go bad?
7e770874-fae3-49d5-ad82-4cabf106fead_zps d3abdb88-50bf-42d8-9628-e257559ec11d_zps
IG: devinthydude
just wink at it lol. if it comes back on for a sec or intermitant mabe check your ground to see if its good or loose. sand off some of the paint if ya havent already when installed it. worse case, WORSE case if all checked out the jensen pooped out.
Since it's an old Jensen, did you check the fluid level in it? If it runs dry, it doesn't work until you refill it.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
lol thats funny. kinda true if it was one of those bazooka amps with the cooling
There should be a screw off of the top and one at the bottom. The bottom one is to drain it, and the one on the side is to check for the proper fluid level. It's set up just like a manual transmission. If yours doesn't have it, you may have to drill and tap some holes, no bigger than 1/4 inch. If your amp is bone dry, use 90 weight gear lube to fill it up.
If you need some pictures, let me know. I can show you where everything is.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Pictures would help ;]
IG: devinthydude
Posted Image
Remove the 2 screws, there's the fill hole.
Posted Image
This is one of the very first Jensen to feature the fluid power. It brought it from 35 watts rms to an astonishing 100 + 100 rms.
Posted Image
Last one I could dig up, Posted Image
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
  • Who's Online   0 Members, 0 Anonymous, 3341 Guests (See full list)
