LiL PiNoY Posted April 28, 2009 Report Posted April 28, 2009 Okay so my head unit goes to 35. On the head unit i have the settings at 10/15 subwoofer, 0 bass, 0 treble I can play it on 20-22 all day without it smelling bad. If i play it at 25 it will start to smell in like 3-4 minutes. whats going on??
tibs Posted April 28, 2009 Report Posted April 28, 2009 amp is most likely turned up to high causing clipping Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
loganuf Posted April 28, 2009 Report Posted April 28, 2009 Okay so my head unit goes to 35. On the head unit i have the settings at 10/15 subwoofer, 0 bass, 0 trebleI can play it on 20-22 all day without it smelling bad. If i play it at 25 it will start to smell in like 3-4 minutes. whats going on?? its called clipping at that level with the sub control at 10, turn it down a little bit....to say 7 or 8, and you should be able to turn it up to 25 ok . but to make sure you prbly wanna set it with a DMM 2000 Eddie Bauer Expedition: Alpine CDA 9883 2x 18" DC lvl 4 D2 10.7 cu ft box 33hz knu 1/0 wire amp: Kicker ZX2500.1 Kinetik
Guest Posted April 28, 2009 Report Posted April 28, 2009 amp is clipping, put volume to 25, sub level on full, and retune gains. (im assuming its a kenwood headunit since mine goes to 35 also and has a sub level control that goes up to +15)
cesarbernal Posted May 15, 2009 Report Posted May 15, 2009 Okay so my head unit goes to 35. On the head unit i have the settings at 10/15 subwoofer, 0 bass, 0 trebleI can play it on 20-22 all day without it smelling bad. If i play it at 25 it will start to smell in like 3-4 minutes. whats going on?? the amp is probably laughing too much
