The reason you would want different Ohm loads is to maximize your amplifier's capabilities.
If you have (2) Dual 2s for example, you could either wire to .5 ohms, 2 Ohms or 8 ohms (I think). If your amplifier is only stable down to two ohms, you definitely won't be able to wire down to .5 ohms. And if you wire to eight ohms, you may not be getting the wattage you need. But wiring to 2 may get you where you need to be.
It's just analyzing what you need in a sub and buying the amplifier to match (or vice versa).
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
so you want to run less ohms?
no, you want to pick out what ohm load subs, for your amp.
you can't just hook up any sub to any amp and get full power, you want to pick out what subs you want, then what amp you want, then go back and do the ohm loads.
it depends on your amp for the most part, and you want them to match
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
