Impedence.. a.k.a resistence.
The less Ohms, the less resist, the more power getting to whatever you want to power.
Get it?
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
diff ohm loads can be wired down different
Dual 4 Ohm - 2 ohm or 8 ohm i think
Dual 2 ohm - 1 ohm or 4 ohm
Dual 1 ohm - 2 ohm or 8 ohm i think
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
Dual 1 ohm - .5 ohm or 2 ohm
fixed em for ya
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
Dual 4 Ohm - 2 ohm or 8 ohm i think (correct)
Dual 2 ohm - 1 ohm or 4 ohm (correct)
Dual 1 ohm - 2 ohm or 8 ohm i think (Wrong)
Dual 1 ohm is 2 ohm or 0.5 ohm.
Edited by kirill007
no, like what is the difference
There is no difference other than getting ohm loads
A Fi btl dual 1 and dual 2 are the exact same sub just your able to drop the dual 1 to a lower ohm
Edited by Team Bassick (ALPINE)
The lower the Ohm rating (impedence or resistence), whatever you want to call it, the more power that can theoretically be harnessed.
If you wire a D1 at 2 ohms, it won't recieve the same power as if it was wired 1/2 ohm.
Think about it being like the nozzles people put on the end of water hoses. Towards the higher end of the spectrum (number wise) you get the more misty, lower power spray. Scale down to the latter, and you're on the jet setting, or power washing.
Or a water faucet;
Water: Voltage
Nozzle: Resistence
Pressure: Amperage
For the most part, no matter what you set that nozzle to the same amount of water (energy) is going to get through, though your chosen setting is what initially determines how efficiently that water (energy, again) is going to get where it's going.
Edited by camino_1to3
Team T3 Audio
Team Sundown Audio
Team O.B.M
However your amp will run hotter on a lower Ohm load (because you are pumping more power through it) and you will have higher distortion from the amp.
But from the subs point of view XXXX watts into 2 Ohms is the same as XXXX watts into 4 ohms.
