Maken a t-line for a comp next weekend.
for anyone who has made one before do you think it would be best for the sub and port to be firing in the cab or sub in trunk port in cab, or sub in cab port in trunk, or both in trunk.
input would be awsome.
thanks
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
if your box fits perfect it the back seat hole port/sub in the cab but if not face em back
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
i have yet to make the box so i can do whatever,
but your sayen have both the sub and port firing into the cab is the best with t-lines in a car?
In Dash
Rear Flip Down
Im pretty sure the only way ull fit a t-line for 2 subs in your trunk is if you make the box to where the subs mounting holes are in the rear package tray. Then have the ports firing into the fold down seat area.
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
its not for 2 subs,
its for 1 re se 12"
In Dash
Rear Flip Down
if it was up to me i would make it to wear it fits in the hole for the back seat meter it then flip it around if its louder towards the front keep it and seal it off but it realy depends on the car ive done both and diffrent results each time
yea thats what i wanna do, just got to find a meter.
a think i may have found one so it should be good hopefully.
bass14 you from melrose mn?
In Dash
Rear Flip Down
testing and tuning is the best way and the only way to get loud and when you meter it do it on a tl
yea i know the tl is the only way to go but i can not find one that anyone has around here
In Dash
Rear Flip Down
are there any show around you if so go to them and if not try to use your ears and see but i dought there will be any diffrence
