Knox_NY Posted May 2, 2009 Report Posted May 2, 2009 ok guys so i have a 2003 nissan pathfinder and im rdy to put some shit in there..some good bump i have 38 width 35 height and 39 depth my original plan is 4 15s in a wall..either 4 orion hcca or 4 btls something along those lines but do u guys think i can squeeze 2 18s btls back there.im doing this in like 2 months so i have time jus need some help deciding,tomorrow i will take pics of my trunk.i rlly want the 18s in a semi wall so i can at least use the rear view,or maybe even facing them up gimme ur thoughts power will be either 2 t40001bd 1 hifonics sampson or the mighty stetsom 7kd if my friend still has it for sale
Pioneer~Saturn Posted May 2, 2009 Report Posted May 2, 2009 Well, you have plenty of room to deal with in either situation (26.5353732638 cubes if using just one layer of mdf around it all..which I'd brace if that was it)...and if you have the room for 4 15's you should definitely have the room for a pair of 18's (you have room for either) And how much lower than the depth you said to be able to see out the rear window like you want for the 18's?...it's probably plenty possible Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Knox_NY Posted May 2, 2009 Author Report Posted May 2, 2009 ok man ill take some pics but wat im afraid of with the 18s is i only have 38" width and 2 18s is 36" then counting in .75" 3 times for the mdf(2 side walls and 1 seperation in the middle).honestly if i cud fit the 2 18s i dont care about seeing back that much id prolly put subs forward ports forward either above or below the subs.but rlly do u think the width will be an issue?
Namosh Posted May 2, 2009 Report Posted May 2, 2009 You don't have to have them (2 - 18's) straight across. If you stagger them they would easily fit. My Ram Quad Cab Blow-through
Knox_NY Posted May 2, 2009 Author Report Posted May 2, 2009 ok kool,sounds good to me,pics soon of the boot
