kfx450r Posted May 2, 2009 Report Posted May 2, 2009 This box is for 2x 15" Fi SSD's i want it to slam. Going to be pushing atleast 800watts to each sub. Box is as follows: 9.15 cu ft after sub displacement but before port. Wedge box 48" wide, 26" tall, 20" bottom depth, 12" top depth. 4x 3" diameter pvc tubing cut to tune to 35 hz. which will be mounted at the top of the box coming to 130 cu inches of port area.
kfx450r Posted May 3, 2009 Author Report Posted May 3, 2009 This box is for 2x 15" Fi SSD's i want it to slam. Going to be pushing atleast 800watts to each sub.Box is as follows: 9.15 cu ft after sub displacement but before port. Wedge box 48" wide, 26" tall, 20" bottom depth, 12" top depth. 4x 3" diameter pvc tubing cut to tune to 35 hz. which will be mounted at the top of the box coming to 130 cu inches of port area. Heres my first google sketchup attempt. This is how i plan for it to look.
bkolfo4 Posted May 3, 2009 Report Posted May 3, 2009 (4) 3" ports is only 28" of port area. Going to get a lot of port noise. (4) 3" ports is no where near enough for two of those 15" drivers. (4) 4" aero ports will work in that box. They would need to be 12" long. I would even double the front baffle (side the subs mount to) making it 1.5" thick. Box with 1.5" thick front would be 8.25 ft^3 tuned to 35 Hz. edit - If you don't use aero ports, then use (5) 4" pieces of PVC, each 14" long. Still is 8.1 ft^3 tuned to 35 Hz using a 1.5" thick front wall. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Ray Posted May 3, 2009 Report Posted May 3, 2009 Vent isn't even close. I'd use 80sq" 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Boon Posted May 3, 2009 Report Posted May 3, 2009 Lol note the 130 CU inch... you want square inches or port, not cubic inches 10.x volts fo' life!
