cunokyle Posted May 6, 2009 Author Report Posted May 6, 2009 how... 8x4=32.... lol whatever program you are using is WRONG... u need at least 11-12sqin per cuft minimum... with aeroports u could get away with 8... That is probably the most absurd thing I have ever read in regards to car audio. You design a box using T/S parameters, not a "rule of thumb" and had you plugged the numbers in you would see that I am correct about these subs. The woofers might suck all the air out your lungs (if you stand too close) When the monster hums
Decaf Posted May 6, 2009 Report Posted May 6, 2009 whats this magical program bbpro? winisd? most absurd thing... dude ur chokin ur subs more than i choke my chicken hmm give about another day and there will be more than me "just trying to help out" saying thats too small for my 2 12s in 4cuft i use 54sqin... more than those two fifteens with 3.5cuft more... and that sounds right?
raytard Posted May 6, 2009 Report Posted May 6, 2009 what program do you have that takes t/s parameters and gives you port size (not being a smartass, i want to port my midbass and port size for a 6.5 isnt something they give you, and winisd only helps so much) also, 18sqin/cube ftw, lol edit: the 12-16 thing I've heard and used with great success...theres a lot of very reputable box builders/designers who use that rule of thumb (my 18 per cube was cuz its 8's...and more of an spl box for fun than anything) Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
cunokyle Posted May 6, 2009 Author Report Posted May 6, 2009 what program do you have that takes t/s parameters and gives you port size (not being a smartass, i want to port my midbass and port size for a 6.5 isnt something they give you, and winisd only helps so much) also, 18sqin/cube ftw, lol No program will "give" you port size. You need to input your port size in any program and then it is trial and error within the program to get your port noise within an acceptable limit with the desired tuning frequency. I use a combination of WinISD, and Liberty Audio Suite for pretty much every design I have ever done. The woofers might suck all the air out your lungs (if you stand too close) When the monster hums
Decaf Posted May 6, 2009 Report Posted May 6, 2009 NEWFLASH... u have to high of a port velocity... if u would like me to check with the box parameters i could back that up more... lol and trial and error over 20+ years has yielded 12-16cuft for daily... per like everyone ever... haha realy tho im just tryin to help or point out what might not have been otherwise and a side note... so did ssaudio do something wrong... 8cuft@35hz.. lol... no name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
cunokyle Posted May 6, 2009 Author Report Posted May 6, 2009 whats this magical program bbpro? winisd? most absurd thing... dude ur chokin ur subs more than i choke my chicken hmm give about another day and there will be more than me "just trying to help out" saying thats too small for my 2 12s in 4cuft i use 54sqin... more than those two fifteens with 3.5cuft more... and that sounds right? I had 4 12"s I had 120 ft^2 cross port area for. I also had 4 12" woofers that used 90 ft^2 cross port area. it differes with different subs. No 2 subs will have the same box specs or the prefab boxes would be the way to go. That is why people "design" their own boxes for their woofers. The woofers might suck all the air out your lungs (if you stand too close) When the monster hums
JPM75 Posted May 6, 2009 Report Posted May 6, 2009 whats this magical program bbpro? winisd? most absurd thing... dude ur chokin ur subs more than i choke my chicken hmm give about another day and there will be more than me "just trying to help out" saying thats too small for my 2 12s in 4cuft i use 54sqin... more than those two fifteens with 3.5cuft more... and that sounds right? "loud 'cause its clipped like a 7yr olds buzz cut" -Decaf "unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
raytard Posted May 6, 2009 Report Posted May 6, 2009 soooooo did you take into account the transfer function? you know, that thing that makes win isd completely and grossly inaccurate unless your enclosure is suspended in the middle of a field? being in a vehicle can drop your tuning by 10hz...or raise it...it does some funky stuff to the standard calculations. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
cunokyle Posted May 6, 2009 Author Report Posted May 6, 2009 NEWFLASH... u have to high of a port velocity... if u would like me to check with the box parameters i could back that up more... lol and trial and error over 20+ years has yielded 12-16cuft for daily... per like everyone ever... haha realy tho im just tryin to help or point out what might not have been otherwise and a side note... so did ssaudio do something wrong... 8cuft@35hz.. lol... no name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> 8 ft^3 at 35hz is not the same box as 7.5 ft^3 at 30hz. See my previous statement about prefab boxes. The woofers might suck all the air out your lungs (if you stand too close) When the monster hums
raytard Posted May 6, 2009 Report Posted May 6, 2009 see, right now you have lance armstrong breathing through a straw posted video is him with his mouth wide open and one of those little nose thingys to open his sinus it doesnt matter if his going uphill, downhill, fast, slow, on a bike or on a unicycle, if he's breathing through a straw he could be doing sooooo much better and dont take it as bashing, build it and prove us wrong, but a bigger port could only hely unless you're giving them way more than rms, or a box way too big (neither of which is an issue in this case) Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
