2 18" Dc Xls 2 Us Amps Md3s & More...
Looks sickk.. Get r done
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
2 Pos runs and no ground huh? And your gonna strap the amps @ what ohm load?
Passport Build Here
Ive yet to run grounds. Was going to yesterday but since batts will be relocated i didnt run them. Might go to the junkyard an get some panels like mine. Cut the panel where the batts would go to gain some space. Only like 2 inches short on the width.
Oh an 1 amp per sub @ .7 ohms each no strapping.
2000 Ford Explorer
2 USAmps MD3Ds
2 18" DC AUdio LVL 4XLs
2 Deka 9A31s
KNU Fleks 1/0 wire
Well got some good work done today. Added Second baffle an bracing, Made both battery trays, cut both panels where batteries are going an ran 2 grounding wires. Battery trays will be monuted to the side of the box made out of 1/2" MDF with some resin for added strength.
Posted Image
Posted Image
Posted Image
Taped up an masked the back off the truck where the panels were being cut. Came out pretty good. I cut a lil too much but its ok cause its all getting covered when done. Oh an Hot plastics burns like hell.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
With final placement on batteries I finished running the ground wires. Found some factory holes on the frame that were perfect for grounding to.
Posted Image
Posted Image
Posted Image
2000 Ford Explorer
2 USAmps MD3Ds
2 Deka 9A31s
KNU Fleks 1/0 wire
