Lack Of Power
antbent86
I have a 2 channel HK802sx ma audio amp. Its pushing 4 12" pioneer premier subs wired down to 1 ohm on each channel. I have 2 batteries and a 25 farad power cap, but after i play it hard for a few minutes all the sound cuts out. Can anyone help me fix this problem, cause its kinda of agrivatting.
Ma amps are power eaters
check to make sure your not cutting out because of severe voltage drops. check to see if your overheating the amp too, maybe cutting in the thermal protect mode
well it gets warm but not extemely hot and it has a volt meter on the amp and they do drop to around like 9
theres your problem. keep that up and youll end up blowing the amp.
get a high output alternator, since alot of the MA audio amps are hungrier than Yoshi.
You successfully got a grin outta me.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Well I got like a 130 amp alternator and I got 2 batteries from the local part store. I don't remember the name.
  • Who's Online   1 Member, 0 Anonymous, 773 Guests (See full list)
