jmanjr82 Posted May 17, 2009 Report Share Posted May 17, 2009 Kenwood DDX 7017 It has tons of options sub out, bass, mid bass, treble etc... Quote Link to comment Share on other sites More sharing options...
white4d96 Posted May 17, 2009 Author Report Share Posted May 17, 2009 oh cool. do you think they would be fine high-passed at 50Hz? Or should I go for 80 or maybe 100? Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
wL<3bass Posted May 17, 2009 Report Share Posted May 17, 2009 50watts rms should be fine, but its going to depend on how you set up your gains and how loud you actually turn it up. The quarts I have dont require alot of power to be honest, Im running a fosgate 400a4 to 2 pair of comp sets and its at 1/4 gain, I dont need anymore then that. If you want I can get the ac clamp and dmm out to get close to exact power they are seeing. Gain is not a volume knob.... Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
jmanjr82 Posted May 17, 2009 Report Share Posted May 17, 2009 When did I say it was? If you have the gain low and crank the volume, you are going to get a clipped signal and distortion like a b!tch. If you turn the gain up all the way and turn your volume you, it wont be long till somthing is smoked...hints why you set the volume then the gain to safely play where you like it etc.....so what was your post supposed to show? As far as where you should cross them will depend on your setup, go with what sounds best to you after all its your ride your the one mainly listening to it. Quote Link to comment Share on other sites More sharing options...
