Longer Shocks To Jack Front End Up With Torsion Key Lift?
ok i replaced my front shocks on my 99 durango with the 5.9 and its 4 wheel drive so it doesnt have the coilovers like the 2 wheeldrive ones do. and well its sitting on the bump stops still. the stock shocks litterly had no oil left in them. so i thought this would fix the problem. i got monroe sensa trac shocks. i dont have hundreds to dump into this thing. so if i got torsion bar key lifts. and it will jack it up acouple inchs but if i got shocks from a liftkit that are 2 inchs longer would it jackup the front end with no problems? if i had the tortion key lift would it work even better? sorry if im babbling or this is a repost. heres a link to the torsion key thing i was gonna get
http://cgi.ebay.com/ebaymotors/3-inch-Tors...sQ5fAccessories
any help would be apreciated. thanks in advance
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
I don't think just swapping to bigger shocks would pick the front end up.
If it's a torsion bar suspension, you might be able to just adjust the bars and get it back to proper height; IIRC there should be a nut or something you can use to adjust the height. Just make sure you get an alignment right after you adjust it!
Too many projects, too little time...
yeah i knew about adjusting the torsion bars well tightening the nut up to lift up the front abit. and the alignment part too. thx. any other help?
oh ok. what about stiffer shocks? im just throwin ideas out my ass btw. i have little knowledge of suspension.
You even need torsion bar keys? Its just a socket...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
a torsion bar keyway lift part i beleive its called. it alllows you to get lift out of your tortion bars without putting too much strain on the stock one i beleive. just look it up. and ik its a socket ill need to adjust them. but i dont wanna over stress the torsion bars so im gonna get them keyways for them to replace the stock ones.
im gonna look up the factory specs to makesure everything is in order.
  • Who's Online   0 Members, 1 Anonymous, 768 Guests (See full list)
