mrafrica Posted May 13, 2009 Report Share Posted May 13, 2009 ok i replaced my front shocks on my 99 durango with the 5.9 and its 4 wheel drive so it doesnt have the coilovers like the 2 wheeldrive ones do. and well its sitting on the bump stops still. the stock shocks litterly had no oil left in them. so i thought this would fix the problem. i got monroe sensa trac shocks. i dont have hundreds to dump into this thing. so if i got torsion bar key lifts. and it will jack it up acouple inchs but if i got shocks from a liftkit that are 2 inchs longer would it jackup the front end with no problems? if i had the tortion key lift would it work even better? sorry if im babbling or this is a repost. heres a link to the torsion key thing i was gonna get http://cgi.ebay.com/ebaymotors/3-inch-Tors...sQ5fAccessories any help would be apreciated. thanks in advance Quote And far as the best connection ever....... get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together. Link to comment Share on other sites More sharing options...
white4d96 Posted May 13, 2009 Report Share Posted May 13, 2009 I don't think just swapping to bigger shocks would pick the front end up. If it's a torsion bar suspension, you might be able to just adjust the bars and get it back to proper height; IIRC there should be a nut or something you can use to adjust the height. Just make sure you get an alignment right after you adjust it! Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
mrafrica Posted May 13, 2009 Author Report Share Posted May 13, 2009 yeah i knew about adjusting the torsion bars well tightening the nut up to lift up the front abit. and the alignment part too. thx. any other help? Quote And far as the best connection ever....... get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together. Link to comment Share on other sites More sharing options...
tibs Posted May 13, 2009 Report Share Posted May 13, 2009 longer shocks are for longer travel.. they wont raise it none. Quote Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace Link to comment Share on other sites More sharing options...
mrafrica Posted May 14, 2009 Author Report Share Posted May 14, 2009 oh ok. what about stiffer shocks? im just throwin ideas out my ass btw. i have little knowledge of suspension. Quote And far as the best connection ever....... get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together. Link to comment Share on other sites More sharing options...
Got_Bass89 Posted May 14, 2009 Report Share Posted May 14, 2009 You even need torsion bar keys? Its just a socket... Quote Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack Link to comment Share on other sites More sharing options...
mrafrica Posted May 14, 2009 Author Report Share Posted May 14, 2009 a torsion bar keyway lift part i beleive its called. it alllows you to get lift out of your tortion bars without putting too much strain on the stock one i beleive. just look it up. and ik its a socket ill need to adjust them. but i dont wanna over stress the torsion bars so im gonna get them keyways for them to replace the stock ones. Quote And far as the best connection ever....... get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together. Link to comment Share on other sites More sharing options...
Loudcav Posted May 14, 2009 Report Share Posted May 14, 2009 sounds like someone before you cranked them down just crank it back up to factery specs and you should be good Quote Link to comment Share on other sites More sharing options...
mrafrica Posted May 14, 2009 Author Report Share Posted May 14, 2009 im gonna look up the factory specs to makesure everything is in order. Quote And far as the best connection ever....... get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together. Link to comment Share on other sites More sharing options...
