korey_hofer Posted May 17, 2009 Report Posted May 17, 2009 so make your own then previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
focalrock4life Posted May 18, 2009 Report Posted May 18, 2009 One of the websites I had found said it it because of the way the barrel is made, it can't withstand the outward loads exerted by newer ammo. look for low recoil loads usually used for shooting trap & skeet. I bet you money i can handle those loads. worth a shot
Aaron813 Posted May 19, 2009 Report Posted May 19, 2009 look for low recoil loads usually used for shooting trap & skeet. I bet you money i can handle those loads. worth a shotMost def itll be able to handle those loads
Sadmule Posted July 23, 2009 Report Posted July 23, 2009 alot of those older type guns use a damascis (spelling) type barrell where it is not rated for modern mag' loads very light loads for skeet or such 'should' be ok but if you can find some older type black-powder shot-shells u'll be fine on those, way slower burn and less chaimber pressure www.myspace.com/Sadmule Manager/Installer @ Custom Acoustics 116 E Church ST Marshalltown, IA 50158 12+yrs installing System of the Month! Come vote on the 20th! http://www.stevemeadedesigns.com/board/ind...showtopic=51696 Here is my install for the running http://www.stevemeadedesigns.com/board/ind...showtopic=50210
