str8outtaneb Posted May 18, 2009 Report Posted May 18, 2009 i have a dodge stratus 2001 2.7L and the other day i decided to run my wires through the firewall instead of the door jam 2 hours later i was pissed off and still didn't have the wire through the firewall my battery is behind my front driver side wheel and there is a terminal type thing upward where i have it hooked up now... and for the life of me, me and my friend cannot find a way through the firewall so i ask to see if any of you have delt with this car and how you did it... if i have to take the wheel off to run it somehow i will have to buy a jack lmk thanks Quote fuck the consequences ain't nothin to a boss
Stephen Posted May 18, 2009 Report Posted May 18, 2009 u know it !! + Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
str8outtaneb Posted May 18, 2009 Author Report Posted May 18, 2009 through the metal?? because we tried to drill through some rubbery shit and it didn't work very well Quote fuck the consequences ain't nothin to a boss
ALPINE408 Posted May 18, 2009 Report Posted May 18, 2009 (edited) + yes throught the metal works everytime!!!! also its a lil ghetto but there are drain plugs in the passanger floor you can come up from underneth Edited May 18, 2009 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown?
str8outtaneb Posted May 18, 2009 Author Report Posted May 18, 2009 ah hell looks like i got to go buy some bits... anything else Quote fuck the consequences ain't nothin to a boss
Forevrbumpn Posted May 18, 2009 Report Posted May 18, 2009 I go thru the drain plugs, or the European clutch/gas pedal plugs if they have them.. lol Firewalls are usually 2 layers with at least 1" to larger gap between the inner and outer, depending on the car model. But yeah, either way Iam sure you will need to drill Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
ALPINE408 Posted May 18, 2009 Report Posted May 18, 2009 its refered to as a step down bit or uni bit drill untill you get the size you want Quote Have you ever had your woofers blown?
Stephen Posted May 18, 2009 Report Posted May 18, 2009 ah hell looks like i got to go buy some bits... anything else they are about $40 each at lowes..... i went to harbor freight and got 2 sizes for $15 Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Forevrbumpn Posted May 18, 2009 Report Posted May 18, 2009 Harbor Freight FTW on the one time use uni bits... lol I will buy the bits from there, and its the skinnier uni bit that will break always for some reason Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
