How To Get Expanding Foam Off Hands
Fuck me, I loled when the great stuff said to wear gloves and eye protection. Well when it started spewing out of the hole as it was expanding. My hands looked liked they were webbed. I tried Orange goop, dish soap, rubbing alcohol, Oops, and the shit still is stuck on there. I had to use toilet paper to stick to my fingers so when i touch stuff I wont infect it with the stickiness.
Anyone have a solution lol.
try nail polish remover?
R.I.P!
(Nov-29-2009)
92 explorer
current build
shamwow?
hahahahahahahaha for some reason that cracked me up
R.I.P!
(Nov-29-2009)
92 explorer
current build
eventually it will wear off......as far as i know its like gorilla glue i doesnt "clean up" well
seriously, it doesnt come off. it has to e mechanically removed. handi foam makes a cleaner for there tools but i dont know if it works on setup foam.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
I tried all that stuff... Paint thinner, nail polish remover, all soaps, ect...
Might try some wd-40
I ended up just pickin it off for like 3 days lol
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
mineral spirits bro, should take it right off. u may lose some skin cells in the process.
use acidtoner it will take that off to but if you aint care fully it will make your hands start to crack if you use it long periods of time (like all day but once or twice a day your fine)
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
i had this same problem last weekend while i was building a science project. i tryed everything as well but nothing worked untill i got out the could old pumice stone and scraped it off while rinsing with hot water. with the stone it comes off pretty easily
