addiction2bass Posted May 24, 2009 Report Posted May 24, 2009 well im not to satified with my 2 type R 12s in my truck, but i have yet to port them. but im planing my next system already for my truck. i want more and until i hit 140db again i wont be happy! im going to limit the power range to 2-3K watts, and box size ruffly guessing i should have 5-6cubic feet to work with since i want to keep 1/3rd of my rear bench seat so i can still have 3 people in my truck. my old truck i had 2 15inch RE SX subs with 2500watts which was kicken 140db which i loved BUT i had the rear seat completely gone which limited my trucks usefulness since it was just a 2seater. and no way i would cut the cab and bed to do a blow thru. i use my bed to much and its only a short bed so i need the whole bed. which do you think would be the better setup for being loud and sounding good for a daily driver? id be tuning the box to 35hz my truck seems to be the loudest at 40-45hz range. my old truck was at 140dbs at 45hz and my new truck so far looks like 40hz with the current setup only 129.8db sealed, ill be porting it this week! and the new 129.8score is with my splmeter i have. i might build a swappable port setup this time just for a comp or daily driver. ill at least make it possible. its way to soon for me to rebuild right away since my yearly comp is already around the corner/ next month so only time i have will be spent upgrading my electrical system and adding a port to my current setup. so ill have a year to piece together my next system.
CaptainzPlanetz Posted May 24, 2009 Report Posted May 24, 2009 well im not to satified with my 2 type R 12s in my truck, but i have yet to port them. but im planing my next system already for my truck. i want more and until i hit 140db again i wont be happy!im going to limit the power range to 2-3K watts, and box size ruffly guessing i should have 5-6cubic feet to work with since i want to keep 1/3rd of my rear bench seat so i can still have 3 people in my truck. my old truck i had 2 15inch RE SX subs with 2500watts which was kicken 140db which i loved BUT i had the rear seat completely gone which limited my trucks usefulness since it was just a 2seater. and no way i would cut the cab and bed to do a blow thru. i use my bed to much and its only a short bed so i need the whole bed. which do you think would be the better setup for being loud and sounding good for a daily driver? id be tuning the box to 35hz my truck seems to be the loudest at 140-145hz range. my old truck was at 145hz and my new truck so far looks like 140hz with the current setup. i might build a swappable port setup this time just for a comp or daily driver. ill at least make it possible. its way to soon for me to rebuild right away since my yearly comp is already around the corner/ next month so only time i have will be spent upgrading my electrical system and adding a port to my current setup. so ill have a year to piece together my next system. Do you mean 40-45hz at 140-145 you are in mid-bass, as far as the subs go are you planning on going ported or sealed, with ported you will make your goal alot easier but it will take more space, with sealed it will take less space but might be harder to make your goal. Edit: you said tuning so that most likely means ported ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
addiction2bass Posted May 24, 2009 Author Report Posted May 24, 2009 ya ill be going ported. o huge typo there.LOL i mean DB not Hz
CaptainzPlanetz Posted May 24, 2009 Report Posted May 24, 2009 ya ill be going ported. o huge typo there.LOL i mean DB not Hz Well doing a bit of research the box for a ported BTL15 would need to be 3-5cubic feet. and the box for two BL12's would be about 5 cubic feet, so basically both setups would be able to get into the 140's pretty easily, so its mostly preference although the BL's will win with cone area, so they have the potential to get louder. But as far as box sizes they are pretty much the same. Edit: whatever combination you choose remember your box makes the most difference, so build a quality box, or have someone build you a quality box. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Guest Posted May 24, 2009 Report Posted May 24, 2009 btl 15 has more cone area than 2 12" bl's edit: x2, its all in the box. dont cheap out and buy one at a best buy or ebay. make your own.
Basshead08 Posted May 24, 2009 Report Posted May 24, 2009 How'd you figure that? 2 12's= 226.08 sq in 1 15= 178.625 sq in System tear out has begun...Out with the old i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell Look at the underlined text hahahahahahahaha I think of it as the virgin losing the virginity technique not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
addiction2bass Posted May 24, 2009 Author Report Posted May 24, 2009 o know how to build the boxes. its going to be custom built! this is my current box i built for a stealth install. lifted the rear bench 4inches, fiberglassed floor. ill be adding the port on the rear middle of the box. ive been building my own boxes for about 5years now. only thing that i usually need help on is t he port area. i know both setups should be nice. but since i havent used either of the subwoofers im not sure which ones to use.
Guest Posted May 24, 2009 Report Posted May 24, 2009 How'd you figure that? 2 12's= 226.08 sq in 1 15= 178.625 sq in i was thinking of an 18", my bad
