5x40 is= 200 it less not more
I can add.
I was refering the the shape of a vent 5x40
something to consider with ports and efficiency is how much air is traveling along a wall or other surface.
5x40" port has a perimeter of 90" and an area of 200"
BUT- a port of say 15" by 13.5" is 202.5 square inches and only 57" of perimeter.
in port #2 more are is traveling in the port and less on the outer edge of the port = MOAR DBs
(which is why a round port is so efficient- least amount of wall to total port area)
-Drew
uhoh_45 said:
im getting so many different answers here... uhh.
First off, i have never seen a wall with aero ports.. i have seen a couple set ups with square vents but i was told as long as im in the 9x1 ratio i would be fine.
also, i can see ray running 160 square inches in a 15 cube box if you are running a ton of power and hitting 157 or whatever at a higher frequency. The unfortunate part is that i already cut. But before i glue the baffle i COULD change it... but most ppl seem to think it is fine.
