this is for two FI BL 15s
ok. im trying to get a rough estimate. fi's website says is should be between 2.8 - 4 cu^ft. and tuned between 28-37hz.
lets just make it a simple 3cu^ft and tuned to 30hz(if this part matter, i dont know) what size box (roughly) am i looking at for two 15's? hope this makes sense
1999 Altima 5spd
HU: Alpine CDA-9887
Frnts: CDT audio 6.5 Components
Rears: Alpine Type R 6.5 Components
Speaker Amp: DAT HR4125
Subs: 2 AQ HDC3 15's coming soon
Sub Amps:(2)US MD2D
Wiring: Stinger
6cu ft after sub and port displacement
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
itll be going in a 99 nissan altima
1999 Altima 5spd
HU: Alpine CDA-9887
Sub Amps:(2)US MD2D
Wiring: Stinger
i think i might be having a total brain fart but what is that in inches?
1999 Altima 5spd
HU: Alpine CDA-9887
Sub Amps:(2)US MD2D
Wiring: Stinger
6-6.5cu.ft. total would be my guess
sealed off from the trunk i suppose?
EDIT: wuts the dimensions of ur trunk
Edited by Sp33dyG
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
Not sure how different the 99 vs. 06 trunks are but 6 cubes in an Altima is no problem.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
im not sure if you will be able to see it but
wheel well to wheel well (towards the back) is 40 inches
side to side towards the front is 53 inches
front to back is 40 inches
height is 17 1/2 before i hit the speakers
height up front did not measure but maybe 20 or so
and the trunk opening is 17 inches
i hope this makes sense
1999 Altima 5spd
HU: Alpine CDA-9887
Sub Amps:(2)US MD2D
Wiring: Stinger
prob going to end up being around 40wx16hx22d depending on the port size to get around 6cuft after displacement using .75 mdf. add more if you put excessive bracing inside the box. sub up port back to make it work.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
this means the subs would be facing up towards the trunk lid and the ports would be in the back of the box facing the seats correct?
1999 Altima 5spd
HU: Alpine CDA-9887
Sub Amps:(2)US MD2D
Wiring: Stinger
  • Who's Online   0 Members, 0 Anonymous, 9449 Guests (See full list)
