Big Power Draw Guys.... Need Help....
Ok here is the run down,
2-us amps AX3200 DE draw 300 amps each
Voltage at idle 14.9 goes up to 15.3 at 1500 rpm.
IT Will not even think about powering both amps at 1ohm load. I changed the wiring config to run just one amp at 2ohm
with the one amp at full tilt does not drop below 14.4 at the amp leads.
1 stock alt 100 amps big three done
1 Mech man 250 amp big three done
1 battery up front 1000cca
in the rear
4 1000cca batts tied together with copper buss bar
1 Kinetic 2400 tied together with 1/0
thansfer is
3runs of 1/0 power and ground to the rear battery bank
Power is tied together with copper buss
Ground is tied together at the same grounding poit as the big three with a 1/2 by 3 inch copper plate at the frame in the front.
Is 350 amps of alt enough????
More grounds, maybe to the rear frame???
dual feeds of 1/0 for the alts, to the distribution point ????
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
One amp draws straight off the Kinetic, with a feed line.
Next Battery has feed line
3rd Battery has second amp feed.
4th Batt has feed line.
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
It really comes down to how you run the system.
If you are going to rail it for short term or for burps then sure you will be ok.
If you want to wang on it all day and the power requirements are greater then what the charging system will allow, then at some point you will will run low on juice.
Adding more runs of power isn't always the solution. It really doesn't help to have enough wire to pull 1000 amps of current to the back of a car when all you have is a 300 amp alt. Sure it will cut down on resistance, but at some point it has little return on the investment.
Thanks King, I was wish I could of at least burped this thing.. Sounds like time to spend some more Money..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
I think this is more then enough for burps.
in the rear
I would even Bassrace with it, but I wouldn't pound all day on it.
That is the problem it draws so much Power with both amps, It won't burp. can't even play at low volume. I can run either amp just fine, but not both at once..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
You have 2 alts and 6 batteries and you can't play the system at all with 2 amps?
I think you need to check a few things then.
Any suggestions on where to start??????
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
