Bunkrd you Posted June 2, 2009 Report Posted June 2, 2009 so i had a beat off comp on saturday and when i got home i found that my ground was loose so i tightened it. also i had it bridged to 2 ohms and didnt realize it and i have 4 ohm subs :/. so they were working then the next day it started going into protect after either a. turning it up to a certain point(18/33 volume) or sometimes as soon as it got a bassy part it would just go into protect. just today i realized dimming and that is an issue but i hooked the amp up to the rml, grnd, and 12v and worked fine then i added rcas and cranked the signal. still fine. hooked up one sub and did the same thing and it still went in protect. its a logic soundlab 1220. i either need A. a second battery, or B. a new amp. i cant tell what the problem is also i dont know if the power dipping could cause the amp to go in protect. Quote
Guest Posted June 2, 2009 Report Posted June 2, 2009 wire your subs to each channel at 4 ohms, instead of 2 ohms bridged, which the amp cant handle. Quote
EricM9104 Posted June 2, 2009 Report Posted June 2, 2009 (edited) so i had a beat off comp on saturday :rofl: :rofl: :01nocomment8so: :01nocomment8so: :01nocomment8so: Edited June 2, 2009 by EricM9104 Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Bunkrd you Posted June 2, 2009 Author Report Posted June 2, 2009 amp goes right into protect still. could i have fried my amp while running it at too low of an independence? Quote
00_XJ Posted June 2, 2009 Report Posted June 2, 2009 :rofl: :rofl: :01nocomment8so: :01nocomment8so: :01nocomment8so: I'm glad I wasn't the only one to notice that lol Quote 2000 Jeep Cherokee -DC Audio -Memphis -Audioque -SecondSkin -Pioneer -KnuKonceptz
Guest Posted June 2, 2009 Report Posted June 2, 2009 :rofl: :rofl: :01nocomment8so: :01nocomment8so: :01nocomment8so: LMFAO amp goes right into protect still. could i have fried my amp while running it at too low of an independence? maybe. open the amp up and look for black/burnt marks. take pics also Quote
Bunkrd you Posted June 2, 2009 Author Report Posted June 2, 2009 no pics but nothing looks burnt. Quote
Bunkrd you Posted June 2, 2009 Author Report Posted June 2, 2009 could having volts drop cause the amp to go in protect mode? Quote
Guest Posted June 2, 2009 Report Posted June 2, 2009 could having volts drop cause the amp to go in protect mode? yep. buy a cheap multimeter and check the voltage at the amp input. Quote
