Big Papa Posted June 2, 2009 Report Posted June 2, 2009 How can you tell if you're getting port noise? On some songs theres a weird sound coming from the box. Could this be port noise or what? 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
velcroslap Posted June 2, 2009 Report Posted June 2, 2009 How can you tell if you're getting port noise? On some songs theres a weird sound coming from the box. Could this be port noise or what? you would know, port noise also know as port wind has a rough pressurized air sound. You would be able to hear it standing next to the port. * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
Big Papa Posted June 2, 2009 Author Report Posted June 2, 2009 so is this "port wind" you speak of just the port vibrating and causing a fucked up sound because it's not braced right? 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
velcroslap Posted June 2, 2009 Report Posted June 2, 2009 so is this "port wind" you speak of just the port vibrating and causing a fucked up sound because it's not braced right? no its from the air being pushed out of the port. your port is acting like a valve, compressing the air before it leaves the box causing a noise. a bigger port can sometimes cure this problem. * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
mxman38 Posted June 2, 2009 Report Posted June 2, 2009 no its because u have to much air coming out of too small of a port... I like to think of it like exhaling out of a really thin straw.
Big Papa Posted June 3, 2009 Author Report Posted June 3, 2009 Oh ok. I'm building a new box soon so I'm not going to worry about it. 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
Ray Posted June 3, 2009 Report Posted June 3, 2009 a port does not "compress" air. A vent resonates the air 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
