^^ thats not true all the way... then whenever you use ring terminals ud be loosing alot... current has alot to do with length.... a 1" run of 4g wire can carry a shit ton more than 140a... a 20ft run of 4g tho would not carry it as well
Basically what I was saying was dont cut the wire to make it fit, especially is you only have enough to reach the amp, each strand you cut lowers the current delivered to your amp. so what I meant to say was use 0/1 guage to the back then use a distribution block(which will allow connection of more amps I.E. a highs amp) and from the amp ground run 4 guage from there and ground to dist. block(seperate) and have the main ground a 0/1 wire. I never cut wire to make it fit, it basically IMO turns it into a lesser wire than you started with.
Edit: and use a hydraulic crimper to connect the terminals Cold Fusion FTW!!!
Edit Edit: Pic of cold fusion weld connection
From Charger's Trooper Build
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
just get 2 reducers, then you wont need any dist blocks and you can just use 1/0 all the way
http://www.hifisoundconnection.com/Shop/Co...sid/0/SFV/30046
i like this idea. I may go this way. and thanks guys for all the input. Its seems like the i have to ground it with 0/1 gauge no matter what. But if these plugs work, then i wont need any dist blocks. i would use all 0 gauge wire and just use the plugs for the amp connections. (correct me if im wrong).
Team Bass-Hz
That plug will work fine, and you wont lower the wires ability to flow the current, I say you would be good to go using that.
¿ǝɯɐƃ ǝɥʇ
sweet picture man!
i get what ur saying but ur picture is proving what im saying... theres less metal in the ring terminal in ur pic... thus that would be the same as just cutting the wire that goes into the amp right... ur reducing the amount of metal to make a connection but because its such a small part... 1" it can still carry the current
the reducers look sexxy tho... my vote is for the cleaner look... i did it the ghetto way when i was cheap and just snipped the wires a bit... same amount of currrent flows with either using the reducers or cutting the wire a bit to fit
Edited by decafcappucino
sweet picture man!
I see what you are saying, I guess that is pretty correct, I guess snipping the wires a bit would yield about the same current drop as if you were to use a dist. block, I was just saying a dist block cause who knows when your gonna wanna add a mid/highs amp, and if you did you would already have it set-up to hook up another amp.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 3434 Guests (See full list)
