so i am going to wire my p1000bd to my car. it accepts up to 4 gauge wire. i am going to wire the front battery to a fuse holder before the amp with 0 gauge. after the fuse holder, i am going to connect 4 gauge into the amp. my question is should i just ground my amp with 4 gauge? or do i need like a fuse block that will go from 4 gauge to 0 gauge and then ground it? thanks
Team Bass-Hz
Use the biggest ground possible.
annd you dont fuse your ground wire.
-Drew
uhoh_45 said:
-Drew
lol what i meant to say was a distribution block. my bad. well the biggest wire i could use is 4 cause 0 gauge wont go into the amp.
Team Bass-Hz
I would just run 1/0 guage all the way back to a distro block or battery (idk what you have) and from there run 4 guage. The 1/0 will let more POWA back. And for the ground, if you could ground it with 1/0 guage and run that to a distro block (or batt) and from there run 4 guage. Hope that helps
Guest KyleCannon
I would do what the person above said... that wire is too big for the RF connectors... use the 0g to the back then to a dist block to 4 gauge then 4 gauge ground to chassis
Use the 0, just cut out some strands to make it fit =D
Which will still make it a 4 guage^^^^^^^^^^^^^^
If 4 is all it accepts that means that 4 guage is all you need, if you run 0guage to the back and then go from a dist. block to 4 guage your amp is still only gonna recieve the current that the 4 guage can supply, take a waterline for instance you have a pipe that is 5 inches in diameter right before it gets to your sink it shrinks to a 1 inch diameter pipe, now are you gonna get the amount of flow that the 5 inch pipe had out of your sink no your not. But 0 guage never hurts, with the dist. block you can power another few amps off of it, same with the grounds, plus if you upgrade to a larger amp you will still have the 0 guage there to work with.
¿ǝɯɐƃ ǝɥʇ
just do this
1/0 has less resistance... cut to fit in.. then u can upgrade later without changing anything...
so do u have a rear bat at all? or just distroblock
^^ thats not true all the way... then whenever you use ring terminals ud be loosing alot... current has alot to do with length.... a 1" run of 4g wire can carry a shit ton more than 140a... a 20ft run of 4g tho would not carry it as well
Edited by decafcappucino
  • Who's Online   0 Members, 0 Anonymous, 3434 Guests (See full list)
