ok box is for 2 alpine type-r 10's 1.3 cubes per chamber ported to 33hz if i did math right box will be 30" wide 14" high and 16.5" deep out of 3/4" mdf
not the best made box in the world but its coming together better then i planned on even tho some of the cuts at off was using very old table saw :/ anyways heres some pictures of it of where its at right now sorry i forgot to take pics befor this point been busy in yard and with kid plus trying to do this all at same time :)
back of the box
back of box close up on port where is it opens to each chamber
front of the box
front of box close up on port opening
not sure on finsh yet once i get is all sanded and routered i might to like a bed liner type of coating maybe or carpet i want something that can take a beating since box will be in back of my jeep and i tend to carry chains tools and what ever else family has me put back there
on and i want to put bolts out the back for speaker hook ups not that i will be changing ohm load or nothing just trying to take cheaper route right now on this box i planned on 1/4" bolts what size eyelets (sorry for spelling) would i need to get to go over the bolts? or should i switch to a 5/16" bolt then what eyelet size would i need for those?
little more done :) not much long now befor box will be ready to use
all rough sanded down and top and bottom screwed in place to make it stronger
all screws per drilled and counter sinked not taking any chances on wood spiltting
inside of chambers silconed to help seal any cracks glue might have missed :)
glueing back in place
almost done back is all screwed on, inside chambers all silconed, just got to make front plate so subs are sunk into the box :)
few pics of me test fitting one of the subs makering holes to pre drill for sub screws
The port going to each chamber in the back looks kind of small. How many cubes and what are the square inches of the port?
Oh and nice use of glue excess for the win :) thats how i do mines
Edited by Crump-T1
each chamber is 1.3 cubes each opening of chamber to port is 1 3/4" wide 10" high then the main port is 2" wide 10"inches high 13 1/4" long i'll post i 3d rendering of how i designed the port i just hope math is done right lol
