LordArcane Posted June 8, 2009 Report Share Posted June 8, 2009 i just made a box and for cheap hook up for the subs i was going to use 1/4" bolts like the comp guys use for quick wiring change my reason is just to save some cash anyways for 1/4 bolt what size ring terminals would i need to fit over the bolt? or if you know what i would need to 5/16 bolt that would work too since i haven't drilled the holes for the bolts yet Link to comment Share on other sites More sharing options...
loganberry Posted June 8, 2009 Report Share Posted June 8, 2009 if you go to say your local ace and get your ring terminals there it says on the package what size bolt it will fit onto, i.e. 1/4, 1/2 etc.. My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
LordArcane Posted June 8, 2009 Author Report Share Posted June 8, 2009 if you go to say your local ace and get your ring terminals there it says on the package what size bolt it will fit onto, i.e. 1/4, 1/2 etc.. ahh ok i was looking on darvex and seen like 10# and stuff now i see i just wasn't looking hard enough thanks Link to comment Share on other sites More sharing options...
