im trying to do some math for my buddy mike (fibtlforlife). he's planning on making a 3.5cuft box tuned to 32hz and he wants to use aero's.
i got 50sqin of port area needed, and that turns out to be 4 4" ports, and a length of 34.87"
how do you make a port length that long? unless im doing something wrong.
Edited by Krannyman92
the box is going to be 15'' in height and about 40'' long to work with for ports. box is really 56'' long but the sub is taking up that extra room.
was thinking about putting the ports out of the box some facing up if i could. which is what we are trying to figure out if i can do that with 15'' if height.
mike
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
when using aeros you can 1/2 the needed port surface area because they are ~50%+ more efficient
so u really only need 3 4"
26.5 total length
1 6" aero might even be the most efficient since it has less surface area of port to create friction... its 28.27sqin... and might act more like 40-55sqin
17.8 total length
the ports come stock with a total length of 17..." anything more than that you have to use ur own center tube... or use a pvc elbow
when u say total length is that for all of the ports combined or for each one..lol i know stupid question but ive never dont flared ports
1 3500d AQ amp
lol damn ok thanks man, time to sit down and think threw the box. i ordered a port already 4'' but its only 17'' long
1 3500d AQ amp
each port
is there any way i can take the 4'' ports and make it were they are 17'' long or less? if i use 4 4'' tubes would that work or no. not to sure on how the tube ports work
1 3500d AQ amp
if u used 4 4" aeros 17" long... aka the lowest tuning with 3.5cuft to work with
17.19" = 45hz tuning... so no... you need to use less port surface area to drop tuning or use elbows and new pvc pipe to get the correct length
which if u are using 4 4"... thats 36"
