Amp Under Seat
LordArcane
ok since i had some left over mdf i'm going to put a peice under my rear seat and mount the amp to it, that will still be air space between the amp on all sides(besides the bottom duh), i've seen steve and many others do it like this in suv, i got jeep liberty limited so i don't think i should have to worry bout amp getting to hot from no air flow. but wanted some other peoples input
so what does everyone think should there be enough air flow to keep amp from over heating?
Depends on the amps class and the ohm load you're running it at. A Class A/B running at 2 ohms might have heat issues, a Class D at 4 ohms will play all day, stone cold.
You also have to be aware of the little hooky bits under the seat pulling wires out if the seats ever get folded.
10.x volts fo' life!
