Grab your multimeter, set it to ohms. Pos on one side, neg on the other, shouldn't matter which way. Should read ungodly low numbers. If you get anything more than an ohm or higher, it's a bad fuse. Try swapping the fuse regardless and try the system, fuses are cheap. It could have been enough to hurt the fuse, but not enough to totally break the metal inside to trip it.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
Well it was just the ground... Heres the story So I hooked up my buddys amp and stuff with 1 12 a while back and he went to local shop and got a little box made with 2 12's a few months after that.. Stupid local shop moved the ground.. Didn't scrap paint and didn't even screw it down all the way so it was wobbleing...
Was weird the Dmm still got a good reading
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
yep figures 9 times out of 10 with that problem thats what it end up being
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
My fault I thought the shop in question could actually do something right... lol
Passport Build Here
Posted (edited)
All fixed.. bxi2008d running 2 of the new soundstream 13's shallow mounts with 5 1/2inch voice coil .. at 2ohms...
Edited by Got_Bass89
Passport Build Here
how do those sound i got a buddy that wants to do shallow subs and he can't find anything he likes, oh and what are the specs on them
Currently in car
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=20701
Also its not 13" sub and 5 1/2" voice coil ITS 13.5" sub and 5" voice coil
There you go bro.. I like them.. They sound good but sucks no shallows will get low unless you have enough space for ported... Then you wouldnt need shallow lol... Also running 500rms to each sub and still taking it like a champ.. Keeps together hella good, might even turn amp up a bit more...
Passport Build Here
