Alright my buddy came over and said his amp wasn't working... I check the voltage on it with engine off and its fine... Turn truck on and amp comes on but 6volts from both power and remote!!! So its putting out no power of course... So im like iunno never seen before, amp might be fucked up.. I put my bxi2008 in there and its fine for a few mins.. Shut truck off and turn back on its doing the same thing... With the hifonics the protect flash then the power flash like start up and then no lights on at all but the blue leds on the front come on... 6V on each power and remote... I tried to jump the remote wire off the power and still does it!!!
Turn truck on with remote unplugged and the amp reads fine 14.4v then hook up remote BLAM 6v and 6v...
Unplugged rcas tried it no help... Checked fuse up front and put new one in.. No help.... Speaker wire at 2ohms like normal...
Donno what else! So Help! lol Thanks
Edited by Got_Bass89
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
did you check his power wire connection and his grounds?... just a thought?
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
double check all the power wires?
missing a ground somewhere?
all of a sudden that start happening?
maybe undo all the wires clean up the contact areas and reinstall.
Edited by tibs
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
check remote wire if its grounded, i had i problem similar and it was the remote wire,,,,,,,,,,,,,,,,,i never thougth it was that you would think radio would not even turn on..........
02g power wire
sundown saz 3500
digital desing 95F
selenium
mechman alt. 250 amp
Do this^^^^^^^^^ I too had a problem like that before the first time is was the remote wire then later on down the road a similiar problem occured and the power was reading about six volts, and the cause of that problem was a crappy ground, got some new 0/1 hydro crimped it and bolted it to a solid sanded ground point and fixed the problem.
¿ǝɯɐƃ ǝɥʇ
Well I jumped the remote wire right off the pos so It can't be the remote wire... I have not tried new ground but have checked all wires...
Passport Build Here
I meter the voltage and use the ground tho so I would think it would be ok
Passport Build Here
Bump it up cuz donno what to do... Ima try new ground later when he comes by but I donno why the dmm would meter good if the ground was bad...
Passport Build Here
Continuity test on the fuse for the amp power wire.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
And how do I do that again?
Passport Build Here
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
