So I just got my box done for my new setup...1 DC Level 4 XL 18"
I'm going to brace it with all thread, but how do I attach the all thread to the box?
<div align='center'>03 RAV4
18" DC Level 4 XL
Knukonceptz 1/0 gauge
AudioQue 2200D
6.25 cubic foot box tuned to 32 hz
DB Linc 200 Amp H/O ALT
1/0 BIG III</div>
With a washer, lock washer, and a nut from both sides. If you want them countersunk then use a small scrap piece of mdf mounted on the inside of the box.
You can see how the washers & nuts ae countersunk into outside of the box.
Edited by Derrick824
alrite that looks good, you think just brace it about how you have it, like a cross
18" DC Level 4 XL
AudioQue 2200D
1/0 BIG III</div>
or u could use 1"+ dowel rods... its cheaper, easier to cut and connect...
and you can connect the dowel together w/screws or by cutting notches out.... much much stronger when u have all the bracing connected together rather than 3 separate rods not working in unison
and you wont have any sign of the bracing if you use dowel whereas allthread is kindof an eye sore... both work just the same as the other
but yes, do left to right... front to back... and top to bottom should be fine for 1 18
Edited by Decaf
ok, I think Ill go with the dowel rods, seems a little bit easier
how do you think it would be best to connect the rods to the box?
18" DC Level 4 XL
AudioQue 2200D
1/0 BIG III</div>
a patient hand to measure correctly
a straight saw blade
1 2"+ drywall screw
wood glue all around
if you can resin/mat the inside of the box that will help alot too
easy enough haha
18" DC Level 4 XL
AudioQue 2200D
1/0 BIG III</div>
easy enough haha
quesrtion i have always used 2x4 and round dowels to do bracing is their any advantage to threaded rod beside strength to volume loss if that makes sense
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
