Ok so here is my dilemma - i'm working on my stereo right now and I've got my component speakers that I need to get hooked up - but i'm not exactly sure what the best setting would be :unknw: I've got a separate amp for them too so it won't be running off the same one as my sub. Of course not LPF since that's for the wang, but should I switch my amp to FULL or HPF???? and if I do need to put it on HPF - would the RCA's work for me, or do I need to hook up the HI input? aaaand if I do need to hook up the HI input - do I just splice from my speaker wires behind the deck?? thanks!!
Currently Under Construction - hoping to be done by August:
JVC KD-SH55 Head Unit
Rockford Fosgate 10" HX2 @ 35Hz
Hifonics Zeus ZXi6.5C (Mids/Highs)
Hifonics TXi4008 (amp for mids/highs)
Hifonics BXi610 (amp for sub)
KnuKonceptz Kolossus Flex 4 gauge - power/ground
50^2ft. FatMat sound deadener
Big 3 - KnuKonceptz 4 gauge
1 Farad Powersonic Cap
Yellow Top Optima
150A ANL Fuse
do they come with a crossover? Full should do the trick if they do.. thats if you want midbass, HPF mainly filters for just the music/vocals and not the bass
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
yeah the components came with a set of crossovers so i'm guessing full should be just fine for me?? here's a little info about them from sonicelectronix.com ---> http://www.sonicelectronix.com/item_6713_H...s+ZXi+6.5C.html
so should full still work out?
Yellow Top Optima
150A ANL Fuse
yeah, i dont have a crossover on mine and have it on full LOL :) but you will need to run your speaker wires to the amp tho
Team DC Audio
hold on now i'm just a little confused ha so which wires am i gonna be running to my amp - the rca's or the speaker wires? thanks for the help btw
Yellow Top Optima
150A ANL Fuse
both.. you need to get the amp to send power to the speakers, so you need to have the speaker wires connected to the amp...
Team DC Audio
you run your rca's from HU to amp and speaker wires from amp to speakers.
* Head Unit: Kenwood KDC-MP732
* iPod Interface: KCA-iP500
* Front Stage: Rockford Fosgate Power T1652-S
* Front Stage Amp: Rockford Fosgate Punch P400-2
* Rear Stage: Alpine SPR-13C Type-R 5-1/4"
* Amp: Rockford T10001bd
* Subs: (2) 15" Rockford P3s
* Front Battery: Optima RedTop
* Back Battery: Kinetic Hc2400
* Wiring: Rockford 1/0
* Big 3: Rockford 1/0
* Enclosure: Idyllic
alright for sure - thanks for the help! as soon as i get the right amp sent to me for my sub, i'll be able to finish the build and put it under the build logs!!
Yellow Top Optima
150A ANL Fuse
just for clarity, so there's no misinterpretation, Run the RCA's from your head unit, to you amp. then you run the speaker wire from the output on your amp to your crossovers then speaker wire from your crossovers to the speakers
HU-------- AMP------ Crossover-----Tweeter/Woofer
Eric
Edited by Duvanator
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
yeah i'll be running the RCA's to my amp, then from my amp i'll connect my crossovers, then from crossovers to speakers/tweets....that's how i'm supposed to wire those up off the x-over
Yellow Top Optima
150A ANL Fuse
  • Who's Online   0 Members, 0 Anonymous, 959 Guests (See full list)
